Pressuse washer troubles
Old 08-24-04, 03:43 PM
I just bought a XR2600 pressure washer with an OHV 5.0HP Honda engine. After using it for approximately 45 minutes the engine cut off...it did not sound like it was running out of fuel but just abruptly stopped. I tried to restart it but the engine seemed froze up. I checked the oil level and some thin-looking oil ran out and I believe there was gas in the oil. I am going to take it back tomorrow but just wanted to get some of your opinions on what could have happened.
Old 08-24-04, 07:14 PM
sceptre
Well, it sounds like you are entitled to a new unit or a refund, if you get any static.
Old 08-25-04, 01:35 AM
cheese's Avatar
Was it full of oil/gas? If it smelled like gas, then you had a carb problem.
Old 08-25-04, 06:21 AM
Pressure washer problems
As per the instruction booklet, the pump is maintenance free and requires no oil. Just wanted your opinions...am going to return it...don't want to void the warranty.
Old 08-25-04, 10:13 AM
Azis
I think Cheese was inquiring about the engine not the pump. If it has an adjustable pressure regulator, make sure it is backed off, I had one with such do exactly as you describe and it was also brand new.
Trackbacks are On
Pingbacks are On
Refbacks are On
