Still wont run right
Old 08-24-04, 04:29 PM
rogerhrt
2 hrp B. and S. motor model#60102 type#0426-01. Seem's like the more I work on this little motor the worst it run's! There's two small wires on the coil . One goes to the condenser and is the other one a grouind?It came out of the starter houseing and hook on to a small clip by the carb. I think its grounding
out the motor! I'm not sure , but maybe someone will know about that one wire. I also disconnected the flapper(governor ?) inside the starter houseing connected to the carb. Will that be a problem other than the rpm's?
Thank's again,
Roger
Old 08-24-04, 07:21 PM
sceptre
sounds like you, let me rephrase that, you should connect your gov. some times if you over rev your engine, the carb cannot supply enough fuel to keep up with the extra rpms, and thus it dies. check to see if your kill wire by the carb is is not grounded.
Old 08-25-04, 01:33 AM
cheese's Avatar
Will it be a problem other than the rpm's?...no, but the rpms is a major problem. It will ruin the engine, possibly blow it, and even the remote chance of injury.
I would forget the points and install a new solid state ignition coil in place of the one you have. The coil for a briggs 3 or 3.5hp classic will work if I recall correctly, and you can probably pick up a used one at a mower shop for $10.00 or so.
Trackbacks are On
Pingbacks are On
Refbacks are On
