B&S recoil starter not disengaging
Old 09-09-04, 09:47 AM
cullen
I picked up an old lawn edger with 2.5 HP brigs motor. When I got it the starter cord was unwound and hanging. I rewound the spring and cord it started right up but was squealing like crazy.. I found if I removed the recoil housing after starting it no squealing...
It seems on the fly wheel (?) there are 4 ball bearings and 4 moving "fingers" that engage and disengage the recoil starter. Looks like it's staying engaged causing the recoil starter to continue to spin making a horrible noise...
Not sure how to fix this...
Thanks
Old 09-09-04, 02:49 PM
puey61's Avatar
The ball bearings you mentioned are a part of the starter clutch. It is this that is causing the squeeling as you will have debris build-up here. You will need to remove the clutch, polish the crankshaft with emery paper, clean out the ID of the piece that slips over the crank and lubricate the balls with a spray lube (such as WD40). The trick is that you should use a proper wrench to remove the clutch and when reassembled it must be torqued to 55 foot pounds as it doubles as the flywheel nut. A Briggs shop can sell you the special wrench - part #19244. Be aware that you will need to hold the flywheel from turning when removing and reinstalling the clutch. If you should use a means other than a proper Briggs tool to hold the flywheel you may break off one or more flywheel fins.
Old 09-10-04, 07:11 AM
cullen
thank you very much, i will try it!
