Drive belt woes
Jack B.'s Avatar
AL
09-10-04, 08:21 AM   #1
Drive belt woes
I have a fairly new Cub Cadet model LT 1018 - Series 1000. It keeps ruining drive belts (part number - #754-0461). Is there anything that can be done to help this? It always comes off the movable flat idler pulley and gets caught above it. :?:
cheese's Avatar
GA
09-10-04, 09:04 PM   #2
I'm not familiar with that mower, but is the flat idler in line with the rest of the pulleys? It may need to be bent or adjusted up/down to get it in line with the other pulleys. If not, is there a good flange on the edges of the pulley? There should be. It should be enough to keep the belt from being able to ride off the pulley. The plastic ones often wear off. Does it have a belt keeper on the pulley to keep it from coming off when the tension is relieved? If so, it may need adjusting. If not, there probably should be.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Jack B.'s Avatar
AL
09-11-04, 11:08 AM   #3
Cheese,
This mower has a hydrostatic transmission...the drive belt has constant tension on it at all times. The flat idler pulley is metal, has raised edges on it...but doesn't have a belt guard. There is a local Cub Cadet dealer who says there is a kit made especially for this problem...and he conviently says they can install one for $65.00.
goldstar's Avatar
OH
09-11-04, 01:30 PM   #4
You gotta love it. " We don't have a problem but happen to have to make a kit to fix the problem we don't have".
cheese's Avatar
GA
09-11-04, 10:32 PM   #5
Yeah, what goldstar said. If it's an inherent flaw in design that they have since revised, then why in the world are they charging you to fix it??! They designed it wrong, and they know it, so how's that your fault?
God bless!
