briggs carb adjustment
cabbageleaf's Avatar
09-14-04, 04:47 AM   #1
cabbageleaf
For future referance could someone explain to me how to adjust my carb with the adjustment screw on the bottom of the bowl for a 400cc 11 hp. briggs & stratton engine type 0638-01 code 85031811 , appreciate it
cheese's Avatar
GA
09-15-04, 12:36 AM   #2
Hello cabbageleaf!
Run the engine at lowest speed and adjust the low speed mixture screw first. This is the brass screw on top of the carb. It should run smoothest at somewhere around 1 1/2 to 2 full turns out from lightly seated. Then, rev up the throttle to full speed. Unscrew the high speed mixture screw (the one under the carb) until the engine stumbles and sputters. Then tighten the screw, counting the # of turns until the engine runs good, then begins to spit and surge. Then divide that # in half, and tighten it that many turns. Fine tuning can be done from there if needed.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
09-15-04, 03:55 PM   #3
cabbageleaf
thanks cheese
cheese's Avatar
GA
09-18-04, 01:47 AM   #4
Anytime!
God bless!
