mower 24v battery WON'T START black&decker cmm1000
Old 09-21-04, 02:08 PM
kackee
makes clicking noise when start lever is pushed
plastic "operation" key (must be in place before engine will start) will not insert fully however, it drops into place when start lever is pushed
"tension" bar (must be held or engine will not start or run) seems to work okay in conjunction with the start lever
battery is fully charged - green LED
please help
Old 09-23-04, 01:22 AM
cheese's Avatar
Received 120 Upvotes on 110 Posts
Hello kackee!
I am not familiar with that mower. Is it a U.S. model? Do you have a voltmeter? If so, check the power at the starter connection when trying to start. Post the results. How old is the battery? Even though the LED shows a full charge, a bad/weak battery is still possible.
Old 03-12-11, 03:09 PM
O
same Problem
Hello,
I am aving the exact same problem with my lawn mower. it is a Black and Decker cmm1000 number 5. If anyone has any advice it would be greatly appreciated.
Thank you
