Troy-Bilt Chipper/Vac Plus, Mdl 47291
Received 0 Votes
Last year, I removed the drive belt from my Troy-Bilt Chipper Vac Plus to clean and then wasn't able to return to it for several days. In the meantime, I forgot how the belt was routed (yeah, I know... I should have drawn a picture!). I routed it as I thought it would be - directly from the Rotor Assembly pulley to the Wheel Drive Pulley, but I have absolutely no torque to to the wheels now. There are two posts between the two pulleys, one with a flat towards the inside and I have tried running the belt between these, but still don't have much torque.
Does anyone have one of these critters and, if so, could you please remove the belt cover and let this dummy know how the belt is supposed to be run?
Thanks,
JimC
Thanks,
JimC
You can find an owners manual or parts breakdown here http://manuals.mtdproducts.com/mtd/public/list.jsp, you will however need your Troybilt model# and serial #.
47291? May be your engine code?
Received 0 Votes
No, that is the correct model number - right off the model number plate and off the manuals. The manual and parts catalog show the belt as a part, but not the proper routing.
Thanks for your response.
JimC
JimC
Hello JimC!
I am not familiar with that unit, but maybe I can help with a little basic rules for belt routing. Generally, the belt will ride with the flat side (back of the belt) on the flat pulleys, and the V side (inside of belt) on the V-groove pulleys. -The tensioner pulley will generally be on the belt in a spot where the belt is going away from the engine, instead of pulled toward the engine, and usually is a flat puley on the back side of the belt. -Most pulleys that have belt keepers will have the keeper in the middle of the length of contact area that the belt has on the pulley. -If it has 2 keepers, they will be close to the points where the belt first comes into contact with the pulley, and the point where the belt begins to leave the pulley. -Both the engine, and the main driven pulleys will have at least 2/3rds of the pulley wrapped with belt. The other pulleys (tensioner and idlers) may or may not. -The tensioner pulley will generally put pressure on the belt in such a way that causes it to wrap even further around the main driven pulley.
This should help you figure out how it went. (I hope
Received 0 Votes
Help! Owners / Operatior's manual for Gardenway (Troy-bilt) model 47291
Help! I've checked the above Troy-bilt site. No good for my Gardenway (manufactured by Troy-bilt) model 47291.
Azis: Your link is great for genuine Troy-bilt models. It doesn't work for my Gardenway 47291. I've entered the model# and s# taken from the metal plate. I've double and triple checked my numbers. No good, I'm sorry to say.
Someone has a 47291 Owner's manual. Help please!
Last edited by cheese; 11-28-07 at 11:15 PM. Reason: removed email and request for services
Received 0 Votes
Gary_KC, Are you looking for the User's Manual and, if so, is there something you are specifically looking for or just the whole manual? I have manuals for most of my equipment in Adobe PDF format, but unfortunately not this one.
If you want the whole manual, I can copy it for you on my scanner (after I get some more paper) and send it. If you just want a page or two, I can scan them and send them attached to an email.
JimC
JimC
Received 0 Votes
Please send 47291 manual
JimC
JimC
Please send the whole thing. You could attach the whole thing as an attachment. Might need to zip the file. I've had 2 other people asking me for this. You'll be helping 3 owners out.
Thanks!
Gary
Received 0 Votes
JimC
Received 0 Votes
Jim
Received 0 Votes
Hello Jim or Gary or Greg,
Do any of you nice guys still have a copy of that Manual for the Troy Bilt Chipper Vac (garden way, inc). I am another person looking for some help. If anyone would be able to email it to me... that would be great!
my email address is **********************
Thanks! Kim
Thanks! Kim
Last edited by Shadeladie; 03-08-09 at 03:39 PM. Reason: Email address removed for your safety.
Received 0 Votes
Thanks! Kim
Thanks! Kim
Jim
Received 0 Votes
Need TroyBuilt 47291 manual
Dear Jim: I'm another Troy Built model 47291 owner w/o an owner's manual. Would certainly appreciate getting a copy of the entire manual if at all possible.
Thanks,
Doug
Thanks,
Doug
Received 0 Votes
Jim
Received 0 Votes
Jim: thanks for the reply and sorry for delay on my part. My email is *******************. Thanks!
Last edited by Shadeladie; 03-08-09 at 03:40 PM. Reason: Email address removed for your safety.
Received 0 Votes
Troy Built Chipper /vac
Jim,
Do you know if this manual covers the 5HP model #47279 as well.
I just inherited one from my mother-in-law and don't know the first thing about running it. I was able to snag a complete parts list and would be willing to make this available to anyone else. Parts are hard to get from what I hear, but the diagrams are clear enough that it may be of some use for assembly. Parts list covers #47278, 47279 and 47282.
I could use a copy of the 47291 just for reference purposes.
Thanks,
John
e-mail *********************
Thanks,
John
Last edited by Shadeladie; 03-08-09 at 03:41 PM. Reason: Email address removed for your safety.
#22
Received 0 Votes
Troybilt part-vacuum snout and parts
I have a Troybilt chipper vac model 47279 Does anyone know where i can get a vacuum snout kit to replace the cracked one that I cant glue together. I cant seem to find a source for troybilt older parts.
#23
Received 0 Votes
Thanks
#25
Received 0 Votes
Mike
#26
Received 0 Votes
TroyBilt 47291/47292 Owner/Operator Manual
Subject manual is available in 6 files (Sections 1-5 & Parts) at 4shared - free file sharing and storage - share folder - TroyBilt 4729147292
#27
Received 0 Votes
Jim,
Thanks,
John
Thanks,
John
Jim
#28
Received 0 Votes
Need Manual for Troy-Bilt GardenWay 47282 5Hp.
I really need a owners manual for a Troy-Bilt made by Garden Way model 47282 chipper/shredder/vac. I purchased it recently and it is like new and now runs great, I would really like to get a copy of an owners manual.. I would be willing to pay someone for copies if they have it.
Thank YOU
Bill
Thank YOU
Bill
#30
Received 0 Votes
I too have a model 47291 shredder vac (Troy Bilt) which was manufactured by Garden Way Incorporated. And, I also need an operator/owner manual. I just joined the forum this afternoon, and I can see what an asset it can be. If you could possibly send the manual to me, I would be happy to help pass it along to future requesters. Thanks in advance. BTW, my email address is ****
Bob Henrick
#31
Received 0 Votes
Mr. Crockett,
I too have a model 47291 shredder vac (Troy Bilt) which was manufactured by Garden Way Incorporated. And, I also need an operator/owner manual. I just joined the forum this afternoon, and I can see what an asset it can be. If you could possibly send the manual to me, I would be happy to help pass it along to future requesters. Thanks in advance. BTW, my email address is bobh127@insightbb.com
Bob Henrick
Bob Henrick
Jim
#32
Received 0 Votes
troy-bilt chipper/vac 47279
I have a troy-bilt chipper/vac 47279 and i'm trying to find a drive belt for it. The part # is 1908537. Can anybody help me locate a new one. I've tried auto parts stores, tractor supply, small engine repair shops and the internet and can not find one. Thanks, jerry
#33
Received 0 Votes
If it were me, I'd remove the old belt and take it to either a small engine repair business or an auto parts dealer. You only need the right length and width - perhaps they can match it.
I just did a double check on the internet for you and found your part at the OK Hardware Store for $15.00.
Jim
#34
Received 0 Votes
troy bilt
I know everyone is asking you and I'm sorry but will you please send me the owners manual for model 47291. I will be so greateful. **************
#37
Received 0 Votes
Troy-Bilt Chipper/Vac Manuals
jamzmom, send me your email address and I'll send the manuals to you. Guess I need to find another location to post the manuals for everyone - one that doesn't delete the items after a certain amount of time.
Jim Crockett
Jim Crockett
#38
Received 0 Votes
I have moved the manual files to a new website. The URL for the new locations is:
https://skydrive.live.com/#!/?cid=06...2FC4B9C390!105
Click on the filename to download it to your pc.
Jim Crockett
Jim Crockett
#39
Received 0 Votes
Your SkyDrive Link for the TroyBilt 47291
Aauugghhh!!! Do you still have this manual by any chance?? We just bought one and the guy didn't have the manual. I figured 'no big deal... I'll just download one. NOT!! Been all over the web with no luck -- until I have your thread.
You would be an absolute life saver if you still have it.
Thanks again.
Thanks again.
Last edited by Shadeladie; 03-10-13 at 01:48 PM. Reason: Email not allowed. Soliciting not allowed.
