MTD push mower with Briggs& Stratton won't shut down
Old 10-01-04, 09:31 AM
joeymon1
I have a MTD mower with a 4.5 hp B&S that won't shut down when the engine control lever is released. The engine slows but does not quit unless I put strong pressure with my thumb on the lever at the end of the control cable. The cable is fine and I removed the cover and cleaned around the spring mechanism.. I can't seem to find any info on how the engine control works or how to fix my problem. The mower is only 4 months old.
Thanks for any help.
Old 10-02-04, 01:19 AM
cheese's Avatar
Hello joeymon1!
Remove the cover so that you can see the kill-switch where the cable connects. There is a black wire that clips onto a small plastic piece. This piece has a metal tab that points down toward a metal arm that should contact it when the cable is released, and disconnect when the cable is pulled. Bend this tab accordingly to make the connection when the cable is released.
Old 10-02-04, 10:25 AM
joeymon1
Thanks. That solved my problem
Old 10-03-04, 02:45 AM
cheese's Avatar
Anytime . Glad we could help!
