briggs and stratton carb.
Old 10-02-04, 10:34 AM
emdrgnfly
Exclamation briggs and stratton carb.
Well lets see I think I have really messed up .. I need help on removing a nozzel from the carberator. It is the one that runs up the shaft from the fuel cup. The thing is that it is stripped out and cannot figure out how to remove it with out damaging the carberator. any help will help greatly.
Old 10-02-04, 11:51 AM
Azis
Largely going to depend on which carb you have. Post the #'s off your engine and we can be of more help.
Does the jet you are trying to remove have a slot on it? If so its threaded if not its pressed. Each have a slightly different method of removal.
Old 10-03-04, 02:43 AM
cheese's Avatar
Received 17 Votes on 15 Posts
Sounds like you may have a 5hp or larger horizontal shaft engine with bowl carburetor. The nozzle, wehn stripped, is very hard to remove and may require drilling. If you're careful, you might be able to work the carb apart (possibly ruining the nozzle) and use pliers to turn the nozzle from the other end to get it out, and install a new one. Without engine model#s, I'm not sure if this is the carb you have or not. Sounds like it though.
Old 04-21-09, 08:55 AM
same problem
Hi Cheese -
I'm having the same problem as described in this discussion thread.
Engine model #252707-0675-01
Nozzle part #231323
I was able to get the old nozzle out (not easily), but then I also stripped the head of the new one when trying to install it.
Is there a special tool to install this part??
It has a head similar to a flat head screwdriver, but much wider, causing it to strip very easily (especially since this part is made of a soft metal and the fit is very tight).
I'm picking up another new part today...hoping you or the small engine shop can give me insight on how to install this part without stripping the head out again.
Thanks!
Old 04-21-09, 12:44 PM
Don't use a regular (keystone) flat-blade screwdriver to remove/install the nozzle. Instead use a 1/4" flat-blade cabinet screwdriver. The shaft on this type screwdriver stays a constant diameter the entire length instead of widening out and making the tip the shape of a keystone. This type screwdriver can be gotten at Sears or Lowes. At the local Lowes they are in the electrical section and at Sears they aren't with the regular screwdrivers but elsewhere on the same aisle.
