Craftsman gas weedwhacker start cord won't pull
Old 10-03-04, 10:19 AM
Remy
I have a Craftsman gas weedwhacker which won't start. The started pull-cord won't give. Anyone have any experience with these or ideas?
Old 10-03-04, 03:45 PM
snoman's Avatar
Remy
What do you mean by "the starter pull cord won't give"? Does that mean your motor won't budge or turn over? What happened to cause this dilemma? Incorrect fuel mixture,carb adjustments?
Let me know.
snoman
Old 10-05-04, 05:32 AM
Remy
thought
The start cord will not pull out when trying to start the engine. It usually pulls out about 2 feet worth of cord.
I am not sure what caused this. It would not surprise me if the fuel mixture has been to light on oil the past 2-3 uses.
Old 10-05-04, 09:09 AM
Azis
I am not sure how many different weed wackers Craftsman makes but its several and without knowing which yours is, it will be hard to provide accurate advice.
A good chance the starter rewind assy has messed up. If the piston has seized there is a chance to free it. What were the circumstances leading to this problem? What model of trimmer do you have?
If the rope starter is between the engine and the boom, there should be 4 bolts to remove the boom and access the rewind assy. Check to see if the rope is tangled or hung. If not remove the spark plug and see if you can rotate the engine one way or another.
If this doesnt help post the model #'s from the unit.
