Removing crankshaft
Old 10-05-04, 02:25 PM
Removing crankshaft
I just bought a bunch of returned Homelite string trimmers and blowers from a large store close to where I live. I am in the process of salvaging usable parts. All of the engines have the same "basic" build-up. The crankshaft is single ended with two ball bearings on the flywheel side. My question is, how do remove these crankshafts and bearings? Any help would be greatly appreciated.
Old 10-05-04, 07:58 PM
sceptre
remove the engine from the housing , then remove the flywheel and cyclinder.
remove the sump cover, slide the piston and rod assy. from the crankshaft. slide the crankshaft out.
Old 10-05-04, 08:23 PM
I'm afraid it's not that easy. All that I have is the crankcase with crankshaft and bearings. I was wondering if maybe I could press the crankshaft out. I've tried wedgeing under the counter weight with a couple of screwdrivers...it will move out a little...but then stops. Some of the crankshafts are approximately 1-1/2" long (on the flywheel end), while others are 4" long...depending on whether or not it has a clutch.
Old 10-05-04, 10:08 PM
sceptre
ive never seen the problem you describe.
Old 10-05-04, 11:58 PM
cheese's Avatar
It's been a long time since I removed one, but I think they just press out on a homelite.
