Overheating Stihl chainsaw
Leedsman's Avatar
10-06-04, 12:50 PM   #1
Leedsman
My Stihl 038AV runs very well but the sprocket/clutch drum gets so hot that it melts the spurgear which drives the oil pump. Does anyone know what might be causing the overheating given that the machine runs very well?
JC
cheese's Avatar
GA
10-08-04, 01:26 AM   #2
Hello JC!
For some reason, this thread was closed. A closed thread will not get any responses, so I opened it for you.
If the clutch is slipping, it could overheat. This could be caused by a worn clutch/drum, chain too tight, bad bar, or other binds in the chain system.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
puey61's Avatar
NY
10-08-04, 03:09 AM   #3
Debris build-up in the oil pump drive area, too, will cause this. Be sure this is absolutely clean.
Leedsman's Avatar
10-26-04, 11:45 AM   #4
Leedsman
The answer!
Found out the reason - the bearings are shot.
Thanks for your ideas.
Julian
cheese's Avatar
GA
10-27-04, 01:29 AM   #5
Great! Thanks for letting us know what you found!
God bless!
