B&S 5HP Runs then Quits
Old 10-09-04, 07:40 AM
robe559
B&S 5HP MTD tiller engine won't start with choke...starts after tipping the tiller forward (get fuel into system?) then runs fine for 30 sec...governor starts pulsing and engine shuts down at 45 sec. This works repeatedly. Ideas?
Old 10-09-04, 10:03 PM
cheese's Avatar
Sounds to me like the fuel pump diaphragm on the side of the carb needs replacing, or the pickup tube is clogged.
Old 10-16-04, 07:46 PM
propliner1
Tried turning the mixture screw in or out right after it fires? Also, look for a good tight connection and gasket at the carb manifold where it goes into the head.
-Brend.
Old 10-17-04, 08:45 PM
cheese's Avatar
This excellent description of the problem: "starts after tipping the tiller forward (get fuel into system?) then runs fine for 30 sec...governor starts pulsing and engine shuts down at 45 sec. This works repeatedly." tells us that the fuel bowl in the tank under the carb is filling when the engine is tipped, and running dry when the engine runs for 30 seconds or so. The reason for this would be a bad pump diaphragm or clogged/missing fuel pickup. I wouldn't change the mixture screw setting since you said it was running fine during those 30 seconds.
Old 10-20-04, 03:07 PM
robe559
Thanx, as soon as I can find the parts, I'll clean the carb and replace the diaphram.
