Sticky valves
tomyboy's Avatar
10-09-04, 01:05 PM   #1
tomyboy
Sticky valves
I have backfiring on a 8 HP Tecumseh Snow King. Pretty sure
its a sticky valve. Any tips on tackling this problem?
cheese's Avatar
GA
10-09-04, 10:02 PM   #2
You should be able to verify valve operation by removing the cylinder head and rotating the engine. Backfiring is also commonly caused by a carburetor problem.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
cando's Avatar
10-11-04, 04:18 PM   #3
cando
sticky valves
You might try Marvel Mystery oil. I have had good luck freeing sticky valves with it. Put it directly on the valve stems if you can get to them and let it soak overnight. Otherwise, add it to the oil & or gas.
Cando
