Engine ID
tomyboy's Avatar
10-11-04, 01:12 PM   #1
tomyboy
Engine ID
Can anybody tell me where the engine model no. and serial no are
located on a 8 HP Tecumseh snow king engine? Looked all over the
exterior of the engine, no luck. They tell me I need it for a carb
rebuild kit. I thought the carbs were all the same on those engines.
Thanks in advance
cheese's Avatar
GA
10-12-04, 12:28 AM   #2
Look on the blower housing for a label or stamped #s.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
snoman's Avatar
CANADA
10-12-04, 05:21 PM   #3
tomyboy
Depending on the age of the motor, it may start with H80 or HM80, or HMSK80
and then be followed by a series of numbers which is the type number and then the serial number.
I believe that it is usually stamped on the housing like Cheese said but check right on the top where I bet your electric starter button is bolted on.
snoman
tomyboy's Avatar
10-13-04, 03:34 PM   #4
tomyboy
Thanks snoman
You da man!! The engine ID was under the electric starter button housing.
Thanks again
