16 hp Tecumseh valve timing
Old 10-11-04, 04:43 PM
brntkndll's Avatar
HELP !! I've got a 16hp Tecumseh from an old Sears ST/16 garden tractor.This engine was given to me in pieces and I am trying to reassemble it for a friend I have no idea how the valve timing should be set up. There is a mark on the case that I assume corresponds with the mark on the cam gear but nothing on the crank.I couldn't find any numbers on the engine but the Sears model # is 143.650012 it's an overhead valve engine and also has two balance shafts. Any help would be greatly appreciated. Thanks.
Old 10-12-04, 12:25 AM
cheese's Avatar
Hello brntkndll!
Line up the mark with the keyway on the gear that drives the camshaft if I remember right.
Old 10-12-04, 12:11 PM
brntkndll's Avatar
Thanks for the reply Cheese. I'm unable to see the key for the cam drive gear because of the pressed on roller bearing in front of it.
Old 10-13-04, 12:17 AM
cheese's Avatar
Look for a beveled tooth on the gear on the crankshaft.
Old 10-13-04, 12:18 PM
brntkndll's Avatar
Cheese, You are the man !!!!!!! Thanks so much for your help.Watching the cam followers while turning the engine over looks much better now. There appears to be a mark in the case by the cam shaft gear but it must just be a casting flaw. What do ya think? Again thank you so very much.
Old 10-16-04, 02:21 AM
cheese's Avatar
Glad you got it! There are almost always casting marks of wierd sizes and shapes inside a small engine block. Probably nothing to worry about.
