Pressure washer won't pull soap in
Old 10-18-04, 05:43 PM
I just replaced the chem.injector on my pressure washser. I can't get it to work It is a karscher gas model .It is the type where you twist it into low pressure and it pull in the soap. The fillter is new new line too Any ideas??
Old 10-19-04, 12:00 AM
cheese's Avatar
There is a tube that the pump draws the soap in through. Look where it attatches to the pump. It should fit on a nipple that can be unscrewed. Remove it and pull out the check ball and spring and clean them and the port they go in.
Old 10-19-04, 01:58 PM
New hose new filter new port.had to replace the whole thing thanks to family dog
Old 10-19-04, 02:03 PM
Azis
Bad Fido
