carb adjustment
kernel1950's Avatar
10-31-04, 03:59 PM   #1
kernel1950
carb adjustment
iI have a 6hp tecumseh motor on a sears snowblower.It starts good but the choke has to stay fully open or the motor stalls.Any ideas how to keep it running with the choke shut off.
snoman's Avatar
CANADA
10-31-04, 06:22 PM   #2
kernel1950
On the bottom of your carb bowl there should be a screw inside a brass looking nut. This is the High speed screw, so after running the motor for about 1 minute, turn this screw out approx 1/8 of a turn (counter clockwise) then try to fully open the choke. If it still won't run, turn it out another 1/8 of a turn. What you are doing when you do this is you are allowing more fuel to flow to the combustion chamber. This is called richening up. If doing this adjustment doesn't help then it will probably be time for a carb rebuild.
Also one other thing, do you use fuel stabilizer? if not....start using it, it gives todays gas a little longer shelf life, and it will work on any of your gas powered equipment.
snoman
Sharp Advice's Avatar
Admin Emeritus
CAL
11-04-04, 06:47 AM   #3
Hello: kernel1950
Find carb help here:
http://forum.doityourself.com/showthread.php?t=76028
Regards & Good Luck
Sharp Advice
Web Site Host & Forums Monitor
Accurate Power Equipment Company
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
rlh74's Avatar
12-10-06, 06:01 AM   #4
choke off
No adjustment ness, If the engine is running with the choke in the open position that is what you want!! Unless I am misunderstaning you.
Azis's Avatar
12-10-06, 07:52 AM   #5
Azis
rlh74...? you are replying to posts that are over 2 years old...?
