Echo Chainsaw-carb problem
Old 10-31-04, 05:34 PM
heron1960
Question Echo Chainsaw-carb problem
I have an Echo CS-3000 chainsaw. It started running only when choked.Thought it was trash in fuel line so i broke down carb ,cleaned it and blew it out.Then it ran OK at idle speed.But when I give it some gas it bogs down and cuts off. Had to replace primer bulb but that made no difference in the way it ran. Thanks
Old 11-02-04, 12:10 AM
cheese's Avatar
Received 17 Votes on 15 Posts
Hello heron1960!
So it still runs ok at idle? If so, try backing out the high speed mixture screw 1/4 to 1/2 turn. It's the one closest to the air filter.
