Need chainsaw help (clutch/sprocket)
Muddy_Newf's Avatar
11-09-04, 07:03 PM   #1
Muddy_Newf
Well I need to get the sprocket and clutch hub off of the crank but the crank keeps spinning.. How can I remove kep the crank from spinning ?
Thanks
Azis's Avatar
11-09-04, 10:49 PM   #2
Azis
most any small engine or auto parts store should carry a plug stop. Basically its a teflon or plastic plug you screw into the spark plug hole, rotate the piston until it rests on the stop.
There may also be a special spanner wrench depending on your saw. If there is it may also be possible to use the same points but improvise the tool.
waterdowg's Avatar
11-10-04, 05:45 AM   #3
I was once instucted by John Deere to use an old piece of starter rope. Take out the spark plug and feed about a foot of so in. I just used a small piece if 1/4 inch cord. It work fine and was cheep.
