5hp tecumseh no spark
markjean69's Avatar
11-10-04, 12:57 PM   #1
markjean69
I hope someone on here can help me. I have a craftsman high wheel weed whacker, no spark. I have changed the magento (old was rusted and didn't check out with vom) good plug. It has no other electronics so what can I do now?
Thank you
Mark
snoman's Avatar
CANADA
11-10-04, 03:39 PM   #2
mark
So the reason you changed the old mag was because it was rusted or because it provided no spark?
Depending on the model and type of motor, if it's an internal coil (under the flywheel) you may have disturbed the ignition timing and may have to retime the motor or if it's an external coil, you have to have an air gap between the magnets on the flywheel and coil. If either are out by too much, you can experience the no spark condition.
There is also another possibility that you may have a grounding wire shorted out, have you checked for that?
If you can give me more info, it would be appreciated. Plus also the model, type and serial number of the motor.
Let me know.
snoman
markjean69's Avatar
11-11-04, 04:23 PM   #3
markjean69
model #: 143.985012
stp185y1gra
external mag only fectronics
air gap is right .0125
Thanks
Mark
Azis's Avatar
11-11-04, 05:06 PM   #4
Azis
Disconnect the kill wire from the coil and check for spark. If you have spark a safety switch or shorted wire is killing it. If no spark then coil or installation is bad.
markjean69's Avatar
11-15-04, 08:22 AM   #5
markjean69
Thanks for the help.
Mark
