Briggs L head ?
Old 11-30-04, 09:31 AM
Briggs L head ?
I looked thru the spec's and kind of assume that the valve specs would be the same for all cast engines but didnt see the 400000 series, 18HP L head twin II listed. Is it the same as the rest? Int and Exh. I could use the head bolt torgue and sequence if available.
Old 11-30-04, 04:21 PM
Not enough data for me to look it up for you, so here is a link to the Briggs website and tech support
http://www.briggsandstratton.com/dis...sp?docid=78484
Old 12-01-04, 06:40 AM
Sharp Advice's Avatar
Admin Emeritus
Hello: sberry27
Additional info below.
B&S codes found here:
http://forum.doityourself.com/showthread.php?t=68787
Briggs and Stratton Home Page:
http://www.briggsandstratton.com/di...asp?DocID=64103
Briggs and Stratton Manuals:
http://shop.briggsandstratton.com/B...EngineType=0436
Regards.
Master Small Engine Tech. Web Site Host, Forums Monitor and Multiple Topics Moderator. "Accurate Power Equipment Company." Engine Diagnostics Services & Repair.
Old 12-03-04, 10:26 AM
I looked it up and they offered the OM but you need to buy the Serv manual I think. I looked up the codes you posted on here in the stick's but it only goes to 300,000 and not the 400,000 series. Are these all the same for valve clearances? Its a Model 42A707 The only thing I really need is the lash specs and head torgue.
Old 12-03-04, 11:37 PM
cheese's Avatar
Hello sberry27!
The lash is:
intake- .004 to .006"
exhaust-.007 to .009"
Head bolt torque is 160 in lbs.
Old 12-04-04, 01:07 PM
Time to drag the valve grinder out and vace the stem ends off a bit. They were down to 002 cold on some of them and it was losing power when it got hot. We checked everything else and that became about the last resort. 6 and 9 is what it will be then. I ordered head gaskets from an outfit called Jakes Small engines I found on the net. My auto parts jobber carries some of it but they were pricey on some stuff on occasion. I was wondering where some of you got parts from.
Old 12-05-04, 12:43 AM
cheese's Avatar
I use wholesalers and there is a large parts distributor in my town that gives me an exceptional discount.
