snow thrower
wis_pea_knuckle's Avatar
01-08-05, 09:06 AM   #1
wis_pea_knuckle
snow thrower
can any body help me. was using my 8 horse snow thrower and it stopped running for no reason. has plenty of power doesnt use oil, but cant start it. can turn shaft on motor back wards and pull starter cable a little ways but then stops abupt. its a 8 horse tecumseh snow thrower motor with electic start. thank you
mla2ofus's Avatar
TX
01-29-05, 09:15 AM   #2
wont turn
From what you describe I think you have a broken rod.
snoman's Avatar
CANADA
01-29-05, 10:10 AM   #3
wis_pea_knuckle
From what the other poster said, i believe that is the situation. Remove the electric starter from the engine and see if there are big cracks or a hole in the block.
Was the oil low or old? This is a main culprit in popping a rod.
snoman
supertech's Avatar
01-30-05, 09:46 PM   #4
broken rod
two causes mostly:
a) governor stuck and engine reved to high.
B) Very cold when started and did not give sufficient time for warm up, thus, starving engine of lubrication;rod seizes to crank and breaks
