tecumseh 8 horse motor
wis_pea_knuckle's Avatar
01-08-05, 09:31 AM   #1
wis_pea_knuckle
my snow thrower has been running great but all of a sudden cant get it to start. acts like it is froze up. took cover off belts and turned motor shaft back wards and tired pulling on starter cable but would only relase a little cant start with electic starter either. has oil and had plenty of power any ideas. thank you
Azis's Avatar
01-08-05, 03:22 PM   #2
Azis
What happens when you try the electric starter? Does it spin the engine?
01-08-05, 04:14 PM   #3
wis_pea_knuckle
to asis121
the same as if using started rope nothing. it acts like its froze up but can turn the shaft that the belts run off of. can turn backwards a little but doesnt let starter rope out enough or the elecitic starter. if i hit starter it makes a banging noice right away.
cheese's Avatar
GA
01-08-05, 09:18 PM   #4
Take the belt off the engine pulley and see if it will turn then. If so, then the problem is in the equipment it is bolted to. If not, then there is a problem with the engine. If it is the engine, see if it is full of oil. If it is out or very low, then there's a good chance there is internal engine damage. If it is full, take the plug out and try. If still nothing, remove the shroud from over the engine and check the coil to see if it is loose and got up against the flywheel.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
