Simpicity snowblower leaking gas
davew's Avatar
01-09-05, 05:00 AM   #1
davew
I have a simplicity snowblower with a 8 hp tecumseh engine. The carburetor leaks gas out of the choke orifice when running or when off. I rebuilt the carb with new needle and seat. Still the same. The engine runs fine. When I pull off the hose at the carb from the primer bulb the leaking stops immediately. When I drop the bowl and push up on the float the gas also stops. Help!!!!
Azis's Avatar
01-09-05, 09:18 AM   #2
Azis
You may need to adjust the float level. The tang that the needle rests on can be bent to allow more or less fuel into the bowl b4 the supply is shut off by the needle and seat. Also make sure the seat is properly installed. The grooved side of the seat should go down.
Refer to this manual for float level adjustment.
http://www.cpdonline.com/692509.pdf
davew's Avatar
01-09-05, 03:10 PM   #3
davew
Simplicity snowblower leaking gas
I have done that. What I don't understand is why there is no leaking when the hose for the primer bulb is removed. It runs great and does not leak at all with it removed. Put the hose back on and it leaks when running and when off.
Azis's Avatar
01-10-05, 08:30 AM   #4
Azis
I would agree that does not seem to make much sense, however not knowing what model engine or carb you have, I can not really provide ne help either. The manual I posted a link to is a complete service manual for all models 3 to 11HP. You should find the info needed there. Perhaps replacing the primer bulb itself.
Or post the model # of your engine.
davew's Avatar
01-10-05, 06:23 PM   #5
davew
Tecumseh engine HM80 - 1552091
Carb # 1099 E6T
cheese's Avatar
GA
01-10-05, 08:06 PM   #6
Remove the float and shake it near your ear. If you hear gas sloshing in it, it is bad and not floating in the bowl to shut off the gas.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Azis's Avatar
01-11-05, 08:56 AM   #7
Azis
DOH!! Ya or that heheh thx for the catch Cheese
cheese's Avatar
GA
01-12-05, 12:21 AM   #8
LOL! Don't worry, we all do it once in a while.
God bless!
