timing for honda G300?
Old 01-22-05, 07:57 PM
pazgas
what is the procedure for setting the timing on a honda G300 8hp engine. i understand that the breaker points are set to 20'btdcand their located behind recoil starter.do i need to worry about screwing anything up? help please. thanks pazgas
Old 01-22-05, 09:50 PM
cheese's Avatar
Received 142 Upvotes on 131 Posts
Just set the points and you should be fine. There's nothing to worry about. The point gap should be stamped on the flywheel...probably the underside...if I remember right.
