toro snowblower only runs when primed
rajung's Avatar
IA
01-19-05, 03:17 PM   #1
I have a Toro s200 blower that worked fine last week and a few days later I tried to start and now will only keep running while the primer button is continually pressed.
Doesnt matter where choke is set.
I removed fuel line at carb. and fuel runs freely from tank.
Re-adjusted the idle and power screws, put back together since it seemed ok .
Started and back to same problem
Thanks for any advice.Never did like these really anyway
snoman's Avatar
CANADA
01-19-05, 07:57 PM   #2
rajung
Since you say that it will only run when you prime it means that the fuel isn't being delivered the way it was meant to the carb. I would replace the diaphragm. Tecumseh has complete carb kits available for those carbs and that is what I would recommend.
snoman
