MTD Snow thrower problem
Old 01-30-05, 08:01 AM
hatvan3105
My MTD 3 HP Single Stage snow thrower develops a couple of problems this year and I hope that someone can help me fix them.
1) I can't stop the engine. it won't turn off through the ignition switch. had to wait until it runs out of gas
2) It won't throw snow. The blade spins but the snow accumulate at the mouth of of the auger
thanks in advance for the advise
Old 01-30-05, 08:39 AM
scan
if you slow the engine down to its lowest throttle position and then set the choke to the full "on" position, the engine should stop.
Old 01-30-05, 04:54 PM
Switch problem
Your ignition switch is not grounding. You can kill it the way scan says, but I wouldn't keep doing it as it could foul the plug.
It sounds like the auger has some severe damage. Check the "flippers" in the center of auger. That is the only thing I can think of to keep a single stage from thowing snow. Also make sure engine is running at full speed.
Good luck,
Mike A
