Starter cord
JBT's Avatar
02-21-05, 01:13 PM   #1
JBT
Starter cord
The starter cord broke on my Toro 8/24 snowblower Model 38083.
What type of rope should I use and how long should it be?
Is this a simple fix or should I take it to the shop?
Thanks for any ideas...
Jim
puey61's Avatar
NY
02-21-05, 02:31 PM   #2
Whether or not you will be able to do the job depends on your experience with rewind starters. In my opinion, a rope replacement is quite easy. Assuming you have a Tecumseh engine, remove the four screws which hold the starter to the housing, remove any remaining rope from the pulley, pre-load the spring as far as it will go, back off just enough for the two respective holes to line up, insert five feet of #5 braided rope, attach the pull handle and you're done. See how easy that was. Or, bring the starter to a shop and they'll likely charge you 8-10 bucks plus the cost of the rope. It's your call.
JBT's Avatar
02-22-05, 08:09 PM   #3
JBT
Got the cord from my local dealer.. 5 feet.. thanks.....
Locking the recoil spring was easy after pre-loading the spring...
Put a pocket screwdriver in the holes... freed up my hands to feed the rope
through... and replace the staple that held it in place......
Thanks for the help....
Jim
puey61's Avatar
NY
02-23-05, 07:14 AM   #4
Excellent job, my friend. It's always good when the job can be done yourself. You know where to find us should you need advice again.
