Hydrostatic transmission
Jack B.'s Avatar
AL
03-01-05, 05:45 AM   #1
Could someone help me out with checking the oil level in a hydrostatic transmission on a Kubota T1400H riding lawnmower? I have just got through rebuilding the engine, (I have a small engine repair shop - business) and due to the rough shape it was in, I feel the need the check the oil level in the hydro-trans. I've got a repair manuel on the tractor that's pretty detailed but it dosen't cover how to check the tranny's fluid level. According to the manuel the hydro-trans holds 0.6 quart of 10W30 oil. Also, where is the drain for the hydro-trans?
puey61's Avatar
NY
03-01-05, 09:08 AM   #2
I am not familiar with Kubota's, so...What make and model hydro unit does it have?
Jack B.'s Avatar
AL
03-01-05, 07:01 PM   #3
I just found out in a Kubota forum at http://www.ssbtractor.com/wwwboard/Kubota_tractors.html , that the hydro transmission is a sealed unit and the oil is only replaced whenever the transmission is taken apart for service. I was about to remove the entire rear fender. I really appreciate your trying to help though, puey61.
supertech's Avatar
03-01-05, 11:33 PM   #4
hydros
hi
just a note--most hydros are never serviced or checked. Manufacturers recommend that you never even open the vent plug. One hair will make it stop moving. Some hydros come with screw on filters and I have witnessed the results of changing it--not good.
S/T
bontai Joe's Avatar
PA
03-02-05, 05:57 AM   #5
I've never heard of a hydro only taking .6 quarts of fluid. Are you sure it isn't 6 quarts? The hydros in my old Deeres take over 5 quarts (I realize it's a different brand made in a different decade, but .6 quarts sure doesn't sound right)
Jack B.'s Avatar
AL
03-02-05, 08:19 AM   #6
According to the service manuel the hydrostatic transmission part holds 0.6 quart of 10W30 oil. The transmission and differiential part holds 1.9 quarts 90 wt. gear oil (which I've replaced). This is a riding lawnmower with a 40" deck. A person in another forum (Kubota forum) said, that this hydro trans is a sealed unit. The only time the oil needs to be changed, is when the case is opened for repairs. I think that the way to get to it, is to take off the entire rear fender.
Pendragon's Avatar
FL
03-16-05, 04:16 PM   #7
Just for reference, my Sears mower also indicates it is a sealed unit and to never ever open it.
