MTD Hydrostatic Mower - rear wheels locked
Old 04-04-05, 12:50 PM
Good afternoon all,
I own an MTD Hydromatic riding mower
YARD MACHINES / MTD
MODEL # 13AS695G118
SERIAL # 1C057H40090
The problem is the brake is off & I can only move the mower about 2 inches front or back. It's like the brake is on or the hydro is locked up.
Ideas?
Old 04-04-05, 09:45 PM
cheese's Avatar
Received 17 Votes on 15 Posts
Are you engaging the hydro release lever/rod? Hydros can't be easily pushed around unless the release is activated.
Old 04-05-05, 05:59 AM
Yes, I've released the hydro.
When you say "can't easily be pushed" do you mean to say that if the hydro is released I COULD push it but it would be hard to do? If so, that's not the case here... I can only move the mower about 2" back & forth before the wheels stop.
Almost like how far you could push a car while it's in park.
Old 04-05-05, 02:55 PM
puey61's Avatar
Perhaps your brake is hanging up in the linkage. On the right side of the tranny is your brake arm. There is a single 5/16" locknut for the adjustment. Loosen this up a few turns in order to eliminate any possible problem at the arm. Also look for any binding in the linkage itself
Old 07-13-13, 06:25 PM
What was the problem with locked up or stuck brake on hydrostatic trans ?? anyone ??
Old 07-13-13, 07:12 PM
Received 2 Votes on 2 Posts
Rick, welcome to the forums. You may have noted that the last post, prior to yours, is eight years old.
If you are having a problem, I suggest starting a new thread with the necessary information.
