Tecumseh Carb Choke Plate Screw - Torx?
JDS-FL's Avatar
04-04-05, 01:36 PM   #1
JDS-FL
I have a Tecumseh HM100 (10-HP Troy Built Shredder) and I can't find a screwdriver to fit the Choke/Throttle Plate screws. T-10 is too big, and T-9 is a bit too small and it will strip if I turn on it.
Are these screws Torx Plus or some other variation? I went to Sears with a screw from the Carb Kit and couldn't find anything there that fit the screw.
Thanks
John
puey61's Avatar
NY
04-05-05, 03:21 AM   #2
This should most certainly be a T-10 driver. I'd say your scrw head is damaged slightly, buy a new screw. The most popular is part #650257 (Tecumseh). Post back with the engine numbers and i'll confirm if this is the one you need.
JDS-FL's Avatar
04-05-05, 10:06 AM   #3
JDS-FL
It is a T-10, must be the Craftsman drivers. I had to really force it in, used a small mallet to seat it in the screws, even with the new screws from the carb kit.
Thanks for your help.
John
puey61's Avatar
NY
04-05-05, 02:49 PM   #4
It is your Craftsman driver. I've found most of their mechanics tools are not to specs.
Azis's Avatar
04-06-05, 09:13 AM   #5
Azis
Are they Craftsman or Sears? They are two different brands and most definately different quality. Sears brand does not carry the same warranty as Craftsman either. I have a lot of Craftsman tools I have no problems with. I need to expand my Torx selection however...may take a bolt with me or somin....
