MTD mower wont start
Old 04-05-05, 03:57 PM
juggalo
okay i have a yard machine LX or thats wut it says on the side its a riding lawn mower at least a 97 because i cant get a owners manual from MTD's site the model number: 13AM6956372 serial number: 1E167H20240
it has all of the fluids it needs an a brand new battery an battery cables an celenoid i belive the blade engager which u have to pull back on to start is either worn out or theres a kill switch somewhere on the engine that needs to be switched over. the engine wont even crank not with the choke out all the way or all the way in its in fairly good condition but im almost certain its some kind of switch because we took it in to a shop last year when this happend an they had it fixed the next day an appeared to have done no wrk on it but it ran if any of you hav any sugestions please help
more specs
engine: briggs an stratton 14.5hp ohv I/C quiet model#:287707 type#:0224-01
Old 04-06-05, 01:36 AM
cheese's Avatar
There is a blade switch. It is located on the inside of the side plate where the blade height lever is. Pull the center plate off where the shift lever is, and look down and to the right (when sitting on the mower) under the dash area. There will be several wires going to the switch. The wires that affect starting are probably orange.
Old 04-06-05, 03:23 AM
puey61's Avatar
I'd replace the switch...part #925-1657A. But look closely and it may just be an adjustment that is needed.
