Engine starts, knocks, and dies
Old 04-08-05, 02:02 PM
skydivejim
Hi All,
I have about 10 air compressors with Hondaís GX 160, 5.5 HP that I am repairing.
Two of these engines begin to start, and as itís coming up to speed, I hear a horrible series of knocks and it quits.
One of them was actually running fine the other day. The only thing I did today is patch up the leaky plumbing on the pump; unrelated to the engine.
These are belt driven engines
Anybody have any clues as to whatís malfunctioning?
Thank you,
Jim
Old 04-08-05, 02:42 PM
puey61's Avatar
Although they are belt drive, you'll need to isolate the engine from the air pump and then run to check. I believe you'll find them to run OK once the belts are off whereas you'll have a pump problem.
