hard starting L-B
Blkbird's Avatar
04-10-05, 07:38 AM   #1
Blkbird
hard starting L-B
I was hoping someone could help.Have a older L-B where it will not start
from just pulling the cord.if I shoot a little ether in the carb then
it starts and will run all day. I've taken the carb apart (plastic
carb with a single bolt on top) changed the float.when checking the
plug it seems quite oily/wet. so I'm assuming it's running rich.If so
how do I lean it out?If not what is the problem
cheese's Avatar
GA
04-11-05, 12:43 AM   #2
I assume L-B means lawnboy? Is the choke closing fully?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Blkbird's Avatar
04-11-05, 07:11 PM   #3
Blkbird
hmmm good question...actually there is no choke control.primer bbulb,on/off switch an a small throttle lever that seems to adjust only for idle?
btw yes i did mean lawnboy
thanx
cheese's Avatar
GA
04-12-05, 12:43 AM   #4
Watch inside the carb throat when you prime the primer. Does gas come into the carb throat? If not, there is a problem in the primer circuit. Could be a bad primer bulb, line, or bowl gasket on the carb.
God bless!
