Old Tiller will not start.
buzzkutt-b's Avatar
04-11-05, 07:43 AM   #1
I have a Moore Handley Home Crafters 5hp tiller. Model #MH56cd Serial BA173851a. Appears not to getting any fire. I changed the gas, put a new plug cleaned the carb with Gumout spray. I sprayed starter fluid in the card and directly into the cylinder, with not even a sputter. I also changed out the pull cord because the old one felt like it didn't have enough tension. I did the test with pliers and looking for a spark, and I even held on to the ignition wire while my wife pulled the cord, nothing. I suspect it might be the coil but I am not sure
how to change it, it looks like it bolts up but the wires are attached to the engine. It is a oldy, but it has always been relible in the past years.
Thanks
gsharpe's Avatar
04-11-05, 08:01 AM   #2
Check for rust on the flywheel. The magnet may need cleaned.
I have had this problem on my gilson tiller.
cheese's Avatar
GA
04-12-05, 01:12 AM   #3
Hello Buzz,
Any idea what make and model# the engine is?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
buzzkutt-b's Avatar
04-13-05, 03:05 AM   #4
It is a Briggs. And it was the points, I cleaned them and it worked great after. Thanks for the input.
BuzzKutt
cheese's Avatar
GA
04-14-05, 01:07 AM   #5
Great!
Next time, just so you know, the new coils are solid state. You install a new coil and forget about the points. They won't be needed anymore, ever.
God bless!
buzzkutt-b's Avatar
04-17-05, 03:16 AM   #6
OK, Thanks
