Snapper 8hp
Old 04-11-05, 07:03 PM
snapperpos
Unhappy Snapper 8hp
I have a snapper rear engine rider. Recently I replaced the drive disk and the hub pulley and plate that turns the drive disk. I removed the motor completely off the frame to replace the hub pulley and plate. When I bolted the motor back down reconnected all the wires and fuel line, and since I put the motor back on the motor turns over but it isn't getting any fire to the plug. any suggestions would be deeply appreciated. Thanks Joe
Old 04-12-05, 12:49 AM
cheese's Avatar
Look for a single black wire coming from under the blower shroud. Disconnect it from wherever it is connected to. Then check for spark. If still none, then the coil is bad, or the black wire is shorted somewhere. If there is spark, then the kill switch or something in series with it is bad or not making contact with ground for some reason (maybe a neutral safety switch).
Old 04-13-05, 07:16 PM
snapperpos
Snapper 8hp
Thanks for the reply. We figured it out it was a split key way thorwing it out of time. thanks for the help though. Joe
Old 04-14-05, 12:40 AM
cheese's Avatar
Good job! You should have had spark then, if it was just the flywheel key sheared. (although it would be out of time as you noted). Either way, glad you got it fixed.
Old 04-24-05, 03:48 AM
tpiersol's Avatar
I recently replaced my aging 8hp w/a B+S 14.5hp. Ran into a similar problem.
Sounds to me like there must be a wire grounding some where. Check all your wiring and replace if needed.
t
