Ariens primer bulb
Old 04-23-05, 11:37 AM
papaw
Ariens primer bulb
Does anyone have info tech manual, or can you tell me how to change it.
Old 04-23-05, 01:40 PM
bambiblaster's Avatar
Whats The Motor Model Number
Old 04-24-05, 11:01 AM
papaw
Ariens primer bulb
looked but could find # must be under the covers. 5.5 hp 22 cut centura motor. bulb is on right side facing the motor and is right on carb on this model. it is red and not black. looks like it has snap ring holding it in place.
Old 04-24-05, 04:55 PM
cheese's Avatar
That would be a tecumseh engine. What's wrong with the primer? They seldom go bad. Many people mistakenly think the bulb is bad if gas is running out of it.
You can use a small thin screwdriver to work the retainer out. The new bulb should come with a new retainer ring, so don't worry about messing it up.
Old 04-27-05, 04:00 PM
papaw
Ariens primer bulb
thanks a lot will not prime pour gas in it starts but can't pump it and start
Old 04-27-05, 09:18 PM
cheese's Avatar
Ok, it could be the primer, but could also be the bowl gasket on the carb allowing the prime pressure to escape instead of push fuel into the carb throat.
