rebuild tecumsehcarb need pics
Old 04-25-05, 05:03 AM
chip t
I need to see how a tecumseh carb is re build had atiller given to me gas runs out of the bowl . got a repair kit but the kit has more parts then i got when tore it down .
Old 04-25-05, 09:13 PM
cheese's Avatar
A lot of the parts won't be used. They include enough parts to make the kit applicable for several models. No single carb will use all of the parts. I think the main thing you'll need to be concerned with is the needle and seat.
Old 04-25-05, 11:26 PM
puey61's Avatar
Also pay close attention to the float for any fluid in it as this will cause it to sink, not float. By the way, you will not find a single book, that i'm aware of, that will show you a step by step of a carburetor rebuild. All books/manuals are too general to do this as there are much too many different models/types of carbs as well as engines for that to happen.
Old 04-26-05, 03:28 AM
Azis
This may not cover every step by step by model, but it does have lots of good stuff and does reference the different carbs. Been a while since I looked but I believe it has a procedure for Tecumseh carb overhaul.
http://www.cpdonline.com/692509.pdf
Old 04-27-05, 04:44 PM
Oregon Sunset
Smile
Score thanks!
