pulsa jet carb
huntingdogdaisy's Avatar
04-28-05, 12:33 PM   #1
huntingdogdaisy
pulsa jet carb
Can Anyone Please Provide Me With A Link For A Diagram Of A Pulsa Jet Carb For A Briggs And Stratton Horizontal Shaft 3 1/2 Hp , I Took It Apart And Not Sure On One Item Thanks ,
Cliff
bambiblaster's Avatar
PA
04-28-05, 12:44 PM   #2
MAY FIND WHAT YOU NEED HERE...
http://shop.briggsandstratton.com/BS...PartsPage.asp?
04-29-05, 10:31 AM   #3
huntingdogdaisy
pulsa jet carb
thanks for the link but believe it or not it does no show me what i need oN THE SIDE OF THE CARB IS A PLATE WITH 4 SCREWS THEN A GASKET AND A SPRING AND SPRING HOLDER I AM NOT SORE IF THE HOLDER OR THE SPRING MAKES CONTACK WITH THAT GASKET PLEASE HELP
puey61's Avatar
NY
04-29-05, 10:53 AM   #4
Carb body - spring - spring cap - diaphragm - cover. Hope that helps.
puey61's Avatar
NY
05-03-05, 12:58 AM   #5
Did you git 'er running yet?
05-11-05, 03:56 PM   #6
huntingdogdaisy
pulsa jet
I got it running but will only run with choke out
cheese's Avatar
GA
05-12-05, 01:23 AM   #7
Those carbs can be a pain in the rear sometimes. Your best bet is probably to disassemble it again and soak it in a bath type cleaner.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
