Ariens Blade Brake/Clutch
Azis's Avatar
04-29-05, 05:27 AM   #1
Azis
I have an Ariens 21" self propelled, model # 911047. The shoes on the Blade Brake/Clutch are worn to the point the blade will not cut. I corrected the cable adjustment with little to no improvement. I called an Ariens dealer and was informed that the entire clutch unit has to be purchased and is around $225.00
The only part that is worn out is the brake like shoes.
Are there any other options or solutions....?
puey61's Avatar
NY
04-29-05, 11:11 AM   #2
I'm not an Ariens dealer or positive but I thought the brake pad was available seperately. I'd get a second opinion form another dealer or check directly with the factory. BTW, the part number I believe you're looking for is 01162200, which is the pad only. Call that first dealer back - anonymously - and see if they have that part number and how much, if so.
Azis's Avatar
04-29-05, 11:47 AM   #3
Azis
Thx much Puey that is the # for the spring pad assy and the same dealer can order for 35.66
Called another dealer with only the model # info and led him to the part lol, confirmed the # 01162200 for 45.00
