craftsman 25cc handheld blower
Help!! Will Not Pull Start. It Died Out And Finally Started After Numerous Pulls, Then Died Out For Good! Will Not Even Pull Anymore, Like It Froze Up. Is It Pretty Much Done? I Think It Is About 2 Years Old. Any Suggestions? Thanks.. Rob In California
Hello Rob!
Are you sure the gas was mixed with oil? If so, check the head ad the end of the shaft. Will it turn easily by hand? If it won't budge, then that's where the problem is. If it does move, you likely have a siezed engine. In that case, toss it and pick up another.
