B&S vertical 18hp won't rotate
Old 04-30-05, 09:11 AM
Question B&S vertical 18hp won't rotate
When I try to start it, it appears to have issues rotating. I gets about one full revolution, and it hesitates or stops. Battery is new. I believe I can also hear metal grinding, but this could be anything.
Someone told me it could be the coil, but that doesn't make any sense. What could the problem(s) be? Any diagnosis?
Old 04-30-05, 10:56 AM
bambiblaster's Avatar
The Coil Rides Bside The Flywheel.... Take Off Blower Housing To Ensure Its Not Dragging... Twist Flywheel Back And Forth If You Hear A Loud Clanking Noise The You Most Likely Have A Broken Rod....
Old 04-30-05, 07:17 PM
cheese's Avatar
If this is an overhead valve engine, you probably need to adjust the valves.
Old 05-01-05, 09:58 AM
I believe it is a L-head twin cylinder engine (model 422707). Is there anything else I might check before I tear the engine apart?
Old 05-01-05, 09:27 PM
cheese's Avatar
Ok, on this engine, remove the starter and check the drive end bushing. Chances are it has a lot of slack and is letting the armature drive itself away from the flywheel and bind. A new bushing or end cap and a bit of grease on it and the bottom bushing will probably get things straightened out.
Old 05-04-05, 03:40 PM
Ok update!
Oddly enough the engine will rotate with the plugs out. It is getting compression and I can feel air so what is up with that? Also, I found I'm not getting any spark on either. Coil pack appears to be dead. Help!
Old 05-05-05, 03:28 AM
puey61's Avatar
Eight screws will remove the blower shroud. Pull the ground wire (the single, smallest wire) off the ignition coil then check for spark. If spark, then you have a bad safety switch - likely the seat switch, if you have no spark then it's time to replace the coil.
