Generic ignition schematic for riding mower with magneto
MeCasa's Avatar
05-03-05, 03:31 PM   #1
MeCasa
I need a generic ignition schematic for riding mower with magneto. I burnt up ignition switch and surrounding wires, I could quickly rewire if I had a basic schematic.
Thanks
cheese's Avatar
GA
05-04-05, 12:29 AM   #2
The wiring of the switch varies greatly among various tractors, makes, and models. There are also many many different switches, although most LOOK the same. So, I think you'll need a specific wiring schematic instead of a generic.
In general, most switches have letters on or near the base of each terminal. B stands for battery positive
M stands for the kill wire (magneto)
L stands for lights
S stands for solenoid
G stands for ground
You may be able to form your own wiring diagram from this info.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
MeCasa's Avatar
05-04-05, 06:45 AM   #3
MeCasa
Thanks you for your reply, I was thinling of doing away with the factory ignition switch and going with a straight toggle switch for powere and a push switch for srarter power. This should be a fairly generic setup
Thanks
BadBoy's Avatar
FL
05-02-08, 05:05 PM   #4
Ignition Switch
Try http://www.overstockdistributing.com...6&cat=0&page=1
they have a ignition switch with key for $6.99 maybe would work for you.
cheers
31YTech's Avatar
FL
05-02-08, 05:42 PM   #5
I think this may be what your looking for, If you don't run the gauge just bypass it from the system;
The charging system above is a Briggs non-regulated and the wire is hooked to the lead with the diode at the plug connector, If you have another brand engine the charging system hook-up will vary. The ignition will vary if you have a fuel cut-off solenoid on the carb as well.
Good Luck
trunkizback's Avatar
IL
07-03-11, 06:18 PM   #6
To Cheese
Thanks for the explanation of an ignition switch..I was going nuts trying to get an older mower running with the switch ( I had been jump starting it ) If you're ever up Illinois way..beers on me..LOL
