Craftsman tractor starting problems
Old 05-04-05, 10:35 AM
punjabi4evr
Hello all, I have a three years old Craftsman 14 HP lawn tractor with a B&S engine. It was running fine until today when i was about to cut my grass. It started up and after a minute it shut off. I tried restarting it, the engine cranks but the tractor doesnt start. If I leave the tractor alone for about 15 minutes it will start again but only for a minute and then shut down. Last time I used the tractor it made a loud noise that sounded like a gunshot, which I thought was probably because of impure oil. But i changed the oil today and still wont start for more than a minute. What could be the problem?
Thanks for your help
Old 05-04-05, 11:55 PM
cheese's Avatar
The backfire was probably ignition related. Have you changed the spark plug? Also, check the plug wire. It may be loose, or might be against the exhaust and shorting out.
Old 05-06-05, 11:10 PM
backfire
Usually a sign of starving for fuel. Probably have some dirt in the main jet. Pour a shot of gas in the carb and then you'll know for sure.
S/T
