troy built oil seal
Old 05-05-05, 04:31 AM
troy built oil seal
2001 troy built pony tiller. The oil seal on the tine shaft is leaking.This happened last year also and I replaced it.There doesn"t seem to be any play in the shaft.It is the same side that leaks.Could there be something else that needs replaceing?
Old 05-06-05, 10:58 PM
leak
sometimes you get a piece of thread or mono-line wrapped up causing a leak. Might have a score or crack in the housing around the seal. The best cure I have found for these is to drain them and fill them with grease. Works much better and no leaks at all. I usually drill and tap a hole and put a grease nipple in it.
S/T
