Removing Clutch on sears 358.795200 weedwacker
Old 05-05-05, 08:02 AM
lgilm118
How do you get the clutch assembly off to fix the starter rope?
Old 05-06-05, 10:47 PM
clutch
Hole in the end of the clutch housing where the cable slides in has a # 20 torx screw in there.
S/T
Old 05-07-05, 05:58 AM
lgilm118
Yes found that but do i have to have a puller the clutch assembly will not come off easy or is there a key of some type?
Old 05-07-05, 09:12 AM
puey61's Avatar
Pull the spark plug, stuff some rewind starter rope in the plug hole, use a water pump pliers and turn off the clutch plate(s). NOTE: curved shaft trimmer will be a standard right-hand thread, straight shaft will be a left-hand thread.
Old 05-08-05, 08:25 PM
lgilm118
Thanks that worked.
