Pressure Washer Problems
Old 05-08-05, 08:03 AM
AEF42
My Pressure Washer does not build up pressure unless I switch the nozzle back and forth a couple times between high pressure and low pressure. It should build pressure as soon as I pull the trigger when the nozzle is set to high pressure. Any ideas on what is wrong with it?
Is there a High pressure switch on the pump?
It is a Sears Craftsman with a Honda engine. Its only a few years old...
Thanks
Andrew
Old 05-08-05, 03:32 PM
bambiblaster's Avatar
Received 1 Upvote on 1 Post
Check Nozzle Head For Obstruction.... Your Owners Manual Tells Ou How To Clean It
