lawn tractor
hillbilly's Avatar
05-13-05, 12:10 PM   #1
hillbilly
lawn tractor
Does anybody know if the threads on the shaft where the flywheel goes are left or rignt handed. Thanks Bill
puey61's Avatar
NY
05-13-05, 03:09 PM   #2
Both top end as well as PTO end will be standard right-hand thread.
hillbilly's Avatar
05-13-05, 06:42 PM   #3
hillbilly
lawn tractor
Thanks for infor, I have the nut off, I took some sewing thread and went around the shaft to see which way it went, but I still hadn't the fly wheel off.
Bill
cheese's Avatar
GA
05-14-05, 03:09 AM   #4
You'll need a puller to get the flywheel off. You can use a steering wheel puller.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
hillbilly's Avatar
05-14-05, 12:13 PM   #5
hillbilly
lawn tractor
Thanks, I have it off, all that to get to the starter. Bill
cheese's Avatar
GA
05-15-05, 11:23 PM   #6
Oh man, you must have an opposed twin engine. You can get the starter off those without flywheel removal just using a 1/2" open end wrench.
God bless!
hillbilly's Avatar
05-16-05, 09:14 AM   #7
hillbilly
Lawn tractor
I didn't think the bolt had room to come out under the flywheel, but if you say it will I will try it next time. Thanks for letting me know. Bill
cheese's Avatar
GA
05-16-05, 11:02 PM   #8
Yep, it will come out with the starter. When you put the starter back on, you put the bolt in the starter hole first, then slip the starter mount under the flywheel bolt and all.
God bless!
