Engine Overhaul - How does the Cam align?
marcum03's Avatar
05-13-05, 05:26 PM   #1
marcum03
I am rebuilding a 12.5 short block Briggs Engine. How do I align the cam with the crank shaft.
I see on the cam gear a dot & also nearby a thru hole.
On the crank shaft, all I see is a key-way slot.
What do I align with what?
cheese's Avatar
GA
05-14-05, 03:15 AM   #2
There should be a dot on the crank gear. It lines up with the dot on the cam gear.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
marcum03's Avatar
05-14-05, 06:04 AM   #3
marcum03
There is no dot on the crank gear. Only a key-way slot.
puey61's Avatar
NY
05-14-05, 09:42 AM   #4
If you have had the crankgear off you may have inadvertantly put it on backwards and now the dot and/or mark is on the back side.
marcum03's Avatar
05-15-05, 11:04 AM   #5
marcum03
You're right, that's what happened.
